New to this hardware, not to entertainment networking. CLU 1.1.2 on Windows 11. For setup purposes I am connected directly to an NS8 on 1.0.0 which is feeding (2) EN4s on 3.0.1. All Windows firewalls are off. When first powered up, the CLU sees all three devices. After a number of minutes (10?) a refresh shows NO DEVICES AVAILABLE. However I can still access them through Chrome by navigating directly to their IP addresses. Power cycling the nodes allows the CLU to find them again, but the behavior is repeatable and consistent. IP and subnets are compatible in the 10.101.x.x/16 range (though I’ve seen the CLU is able to see nodes even if they’re incompatible). I believe unrelated, but the only tweak I’ve made beyond basic IP/name stuff is changing the IGMP querier from auto to custom and assigning the querier IP to the switch’s own IP. However this behavior occurs whether the IGMP settings are on auto OR customized.
UPDATE: I realized that the node was dropping sACN transmission around the same time, which made me revisit the IGMP settings. I’d failed to put in values for the query intervals, maximum response time, etc, so I added them. This brought the sACN back on line, but now after 10 or so minutes the CLU fails to see the NS8 (though it DOES see the EN4’s downstream now) BUT I CAN NO LONGER EVEN ACCESS THE NS8 THROGH ITS IP INTERFACE. I can also no longer even ping the NS8 at its address?! Running wireshark shows the NS8 is still alive at its IP (10.101.170.111) but has no traffic at all beyond a group query every ten seconds. It passes traffic but there is no longer a way to interact with the switch at all. Again, a power cycle brings it back to the CLU and the IP interface, but that’s a hideously not ok solution for something going into a lighting rig.
The forum won’t let me embed two images, so I can’t share the wireshark demonstrating the NS8 is, in fact, online at IP 10.101.170.111, but only sending a group membership query every 10 seconds and nothing more.
Below is ping results (‘.111 is the NS8, ‘.112 is one of the EN4’s downstream of the NS8):
Someone please help me out here. Surely I’m missing something?
Thank you.
