Connect EP4 Node with GrandMA2
Hi Folks,
I dont even know if I have a Issue now or not but…
I have a video shoot on sunday where I have to provide a timecode show and the location has a MA2 Command Wing for lights, as the video crew brings 8 Titantubes as additional lights there is a need for a third universe which i wanted to play out through the EP4. I tried to configure it and it looks like my PC is playing out ArtNet … yellow light is blinking fast and when I end the session in MA2 it stops. But the outputs on the EP4 are blinking. When I connect the node via ONYX the outputs are constant. I know that i wont see a third party node in the ma software. As I dont have any fixtures at home I cant test the output. Does anybody know if the incoming artnet is still recognized and played out in this use case?
THX in advance
and yes I have a commandwing connected to my PC so the output is activated in MA , I can also see the data in the artnet monitor software
Check the Art-net address mode in the EP4 and try the alternate 0-0 or 0-1 setting. You probably are sending the wrong Universe from the MA.
Youre the man… at least it looks right now. Just found out that you can change the DMX input to an output on the command wing, so I will be safe no matter if its working now. But still a big thank you as it seem that your tip brought the solution.
