Hi
I’m trying to control ONYX using OSC from ShowCueSystem software and I have some issues with establishing a connection.
After I’ve failed to connect those two, I’ve tried to connect touch osc to control ONYX and I couldn’t do that too.
I’ve checked IP adresses, in and out port. I’ve tried the connection on diferent computers, using connection through wifi and ethernet line.
Osc monitor on laptop shows all of the messages, but does not give the message to ONYX.
Does anybody else got same issue with OSC, some ideas what else can I check or change?
you might find it is more active at
usually only takes an hour or two to get an answer from the hive mind.
