I’m trying to use a conventional console to have more faders with onyx on a PC. i use the martin usb dmx interface. My conventional gets in on A and my output dmx is on B. I selected " merge" in options. My problem is that the onyx grandmaster doesn’t fade the conventional, the channels I send with the conventional stay “on”.
The grandmaster doesn’t control merged values that are simply forwarded to the output. It would not know which dmx channel to move as an intensity.
Use DMX In Map to assign incoming dmx values to generic channels patched to the correct addresses.
hi again, I did the mapping with good parameters and it works fine ! But still have an issue : I want to keep my audience lights NOT to be controlled by grand master. I looked in the partch but did’n find nothing.
Hi matthias, I found a solution, I did a playback for audience lights, and with the patch if I remebmer well, I could ask that it is ignored by the grandmaster.
