Cue name disappears ...
Software Version: 1310
NX Console Type or PC OS Version: NX1 and on PC
Almost a random, when we EDIT a cue, the name of the CUE will disappear from the cuelist. Sometimes it happens with every edit and in a few minutes, it is not happening at all.
It happens whether we are in EDIT MODE or not.
This is happening on our NX1 and on our PC.
Are we missing something or doing something wrong?
Thanks … Brent
Hi Brent,
With Cuelist Edit Mode enabled, if you select a cue’s name, this will bring the CUENAME command onto the command line. If you then start typing a new command, such as EDIT CUE, this will remove the cue’s name, even if Edit Mode has since been disabled.
A cue’s name cannot be edited directly through an EDIT CUE command - the cue name can only be edited through a CUENAME command, which is accessed by clicking the cue’s name in Edit Mode.
If the CUENAME command is on the command line by accident, it is therefore important to press CLEAR to cancel, rather than pressing ENTER or starting a new command.
Thank you! Thank you! Thank you!
I will pass it on to my team members immediately.
Cheers … Brent
No problem at all! Please let me know if you have any questions.
