We have a Netron EN4 daisy chained to a couple of EP4 for controlling our stage and house lighting.
Universes 1-2 are used for the stage lighting, 3-4 for architectural.
We are using a couple of Springtree SM-8 8 button switches to trigger cues on the EN4 when Onyx is not being used to control everything (Port 1 of EN4 is listening to channel 512 of universe 4 which is what the Springtree sends to trigger the inputs).
Right now though we have to physically disconnect the Springtree and run a No Cues in the Web Portal in order to be able to take over with Onyx; I’d love to do away with this.
The Springtree allows a single universe of DMX to pass through, so I’ve connected an aSCN node its input, and sent through the value 105, channel 512 on a universe 4 in order to trigger Input 10 on the EN4 that plays the no cue setting.
This works, in that it disables the Springtree buttons (so pressing the switch buttons stops any cues) and triggers the Input on the EN4 with the words No Cue showing on the OLED; but Onyx is not able to control of anything on Universe 4. It’s like the EN4 is still transmitting the values of the last cue that was triggered and nothing I send from Onyx seems to be send on.
I think it may be to do with the Inputs in the EN4 being set to trigger instead of toggle, but I’m not sure.
Is what I’m hoping to achieve possible?
