Request to customize the Flash button level in the Flash Timings settings. Or it could be a popup fader option to quickly adjust it from within the right click popup window.
You know, I really don’t want the Override setting to “flash to full” when using the Flash button. Here is why. A Q-Blender Override carries the full range of the setting. Often I don’t want to flash to the maximum speed when hitting the button. I only want to flash to maybe 75% to 85% of the potential speed of the fader. I don’t want to max out the fader by hitting the button because that would be too fast. Neither do I want to create a Q-Blender where the maximum speed is slower than desired, because then one can’t make it go faster if needed.
