I think currently it is only able to put these values in a cue. Very cool would be to have that store in overrides so that you can play with how cue changes like colors, dimmers, whatever change in larger setups.
Afaik this is currently not possible
This is an interesting idea. This would require a change to how Fades and Delays work - at the moment a cue runs these timings based on what is stored in the cue itself. Therefore instead this would require cues to listen to Fade and Delay information from elsewhere.
Currently, the “Global Fade Speed” encoder can be used to speed up or slow down cue transitions on the fly.
Yes thats true, but with that “feature” it would be even more flexible.
To be honest I would somehow guessed that this already works as you can put other values like steps or waves into cues or whatever. But yes the implemenation is different I guess.
