hello, is it possible to input digital values (0-255) for a generic channel via comandline?
thx.
Software Version:
NX Console Type or PC OS Version:
nx1
4.30.74
thx.
Software Version:
nx1
4.30.74
In the parameter programmer you can set the value mode to digital value to see the values represented in 0-255 (0 - 65025 pan/tilt fine). Then its just a matter of setting your dimmer from 0 to 100 with the decimal afterwards
example to get value 243
fixture x @ 95.4
Press ‘@’, followed by the button for the channel (in case of NX1, press down the corresponding encoder) whose value you want to set, and then you can enter the digital value.
thank you, found it.
P.S.: the unit for entering channel values this way actually follows the digital/percentage setting gogocharter mentions
