DMX Settings>Local DMX>remember last ports? (NX Wing)
Software Version: 4.32.1314
NX Console Type or PC OS Version: old (128 uni) Windows 11
When I start up each morning, I have to go into DMX Settings>Local DMX and re-assign the DMX ports on the back of my NX Wing. They revert to default each time I start Onyx. Didn’t these used to retain the settings last used in the showfile? Is there a way to get these to retain these assignments?
Hi @Onlyslightlybent
I suspect your NX WING’s DMX cards are running an older version of firmware.
To confirm, please connect the NX WING, and go to ONYX > Menu > Tools > Diagnostic > Firmware Update. In here, please check that the NX DMX devices are running v4.14. If they are running an earlier version, select them, and click Update USB Firmware. Go to the NX2 - NX WING folder, and then choose the latest firmware file for the matching USB device ID (E_A9).
Edward’s firmware check is the right first step. If both NX DMX devices already report v4.14, try re-running the USB firmware update anyway, then reassign the local ports and save the show before rebooting. Also confirm Onyx is loading the same showfile at startup—if it opens a different or default show, the port assignments may look like they reset. If it still reverts, note whether it happens on a simple restart or only after a full power cycle, as that helps narrow it down.
