Dylos Bugs PC 4.32.1307
Had an issue this morning where certain fixtures in a Dylos zone would not get any output from Dylos. We have some battens and a few pixel light bars in two separate zones. A few of the Battens would output but none of the pixel bars and about 6 of the 14 battens would not output either. Upon looking up the live output tab, we could see that Dylos was outputting, but only certain fixtures showed values, the ones that were working properly. I checked the 2D plan to make sure no zone boundaries changed, but they all were inside their respective boundary, but the fixtures were blank in the 2D zone for the ones which were not outputting. I then rebooted the computer and it corrected the issue. One thing to note, when I closed Onyx, I got a “Class Error,” which I acknowledged before I continued to reboot the system. Also, the Live Output module would not work on some screens, as it will not display any values. Probably unrelated, but I figured I would mention it.
Hi @ControlsEE
Thank you for the information. Sorry to hear you encountered this.
Could you have had manual values for these fixtures in the programmer, that were overriding DyLOS?
As you could not replicate this issue after restarting, it may be difficult to troubleshoot. However, if you could send a copy of your show file to support@obsidiancontrol.com, we will be able to investigate.
Sure thing. I apologize for the delay as I have been out since then.
No problem at all. We have received your show file, and will investigate.
Had another issue this morning, Mid-service. All of a sudden, none of the playback buttons would trigger. They are setup to either go or toggle, but when clicked, they only highlight, but do not execute. Had to restart in the middle of a service to regain control. Not good. Please advise.
Hi @ControlsEE
In the Playback Buttons window, please ensure that the Mode option at the top is not set to Select
That was the first thing I checked. It also happened across the board, reguardless of which screen I was on. Any on-screen (non-hardware) playback would not fire.
If you are not already running ONYX 4.32.1314, I would recommend updating. ONYX 4.32.1314 can be downloaded from the link below…
https://files.obsidiancontrol.com/s/Onyx-4-32-1314/download
Installation instructions can be found here…
Updating to 4.32.1314 is the right first step. If it recurs after updating, save the Onyx log before restarting, note the exact time, and try a single newly created playback button in a fresh show. If that fresh button fires normally, the problem is likely in the show file; if it also only highlights, it points more toward the software or input layer. Keeping the pre-restart log is important because restarting may clear the evidence.
