DYLOS inside Cues Flashing White Problem
Software Version: Latest Onyx
NX Console Type or PC OS Version: Both
So when recording a DYLOS cue, when it’s time for the DYLOS cue to go it flashes white briefly on whatever fixture is in that zone because it’s fading up or turning on the DYLOS. I can’t figure out how to get a cue to fade in smoothly when it has DYLOS in it. I’ve tried a fade parameter intensity and it didn’t help. It’s like flipping a light switch on when DYLOS kicks in. I also notice with DYLOS off in that cue, all of my lights are bright white but when I move the DYLOS intensity to 100% it turns it to the color I want in this case pink. Anyway to fix or remedy this for future cues?
RGB fixtures are set to 100% on the color channels by default. Simply set that to be defaulted to 0 (set the color channels on 0 and record that into the default “store”) and thats it. Now Dylos will smoothly fade in without fading over white.
I should have known that, I just assumed it didn’t apply to DYLOS lol, thanks for the tip!
