So, I am programming a zoom/intensity effects like can be found here . After a while of playing with the effects linking (first time I’ve linked effects, so that’s nice to have learned) I finally got the idea of the look I’m going for, but the issue I’m running into is when the effect starts over it just stops for a second then goes through the effect (check attached video for example). Am I missing something to make this a smooth effect? Wait under FX Timing is set to 0 sooo…
So is there anyone who can help with making a seamless loop, or am I just out of luck?
hello, have you tryed to set another " base ",
for the atribute you want to apply the effect?
r.h.
