I can’t find any documentation on how to configure the DMX Merge on an EN4. I’d like to potentially merge 2 sACN streams using HTP.
Have you read the EN4 manual yet from the product page? There it should show you how to set the merge functionally. But in short, when you configure the DMX output ports, there should be a merge function that is set to off, just change it to HTP. Start there. You may run into, console defaults also, as far as if one unit say (as example) color values at full vs at 0.
NETRON EN4 EP4 EN12 EN12-45 - USER GUIDE 2022-05-25 (d295jznhem2tn9.cloudfront.net)
