EN4 Version 2.0 is available for download from the product page.
https://obsidiancontrol.com/en4
Release Notes for NETRON EN4
(C) 2020 - Obsidian Control Systems
V2.0 (06/01/2020)
This version requires two files, .DFW and .IMG
Improvements
Added better support for setting options from DMX Workshop
Device Name
Identify device with red/white blinking LEDs
Port Direction and Universe Settings
IP Address -
Added System option “Artnet Offset”
Universe 1 is mapped to Artnet 0-0 (compatible with ONYX/M-Series)
Universe 1 is mapped to Artnet 0-1 (compatible with newer Artnet 4 devices) -
Universe Range for Artnet and sACN is now 1-32767
Home screen shows device label is display for easer identification
Added Web Firmware version to Status Page
Added automatic forwarding when changing manual device IP address
Bug Fixes
- When the port set to input,playing CUE changed the ports of the direction
- Current cue was not updated in display
- Improved RDM discovery for Elation Fuze Range and others
- Fixed bug with 2.x.x.x automatic IP calculation
- Firmware Update is no longer case sensitive (both .dfw and .DFW will work)
- Artpoll packages identify port count correctly
