i have an EP2 connected to a ratpac AKS+ and an ipad running Blackout Lighting Console via ArtNet Directed Broadcast. its connected directly to the ethernet port on the AKS+, not through a switch. Blackout is transmitting multiverse data. i have the EP2 config’d for universes 2 + 3. the blue lights are flashing so its not receiving data. if i switch the ports to uni 1, the blue light goes solid (receiving data). then if i switch back to uni 2 or 3. the lights stay solid and transmit data. ??? no idea why this is.
This looks to be due to the Artnet Universe offset. You can adjust this in the system menu.
