Is there a way to exclude a channel/fixture from being cleared (including CLEAR-CLEAR)?
We’ve got some dimmers being used in switch mode to remotely power-down some difficult-to-access fixtures and I don’t want them to get power-cycled accidentally/unnecessarily.
maybe, use Park. and park the special dimmer.
CLEAR-CLEAR is used to clear the programmer. If you have equipment that you don’t want to be turned off, why don’t you just use a Playback for them? You can also use a subdimmer, you can set PARK to them. It has several options.
