Hi to all!
Could it be possible to export cue values for Theater use. or maybe add a button print as pdf for selected cue.
Thank you.
Yes I know that type of report but needed a more detailed cue by cue for Theater use.
Yes, it would be useful.
Is this a thing yet?
I am about to migrate from a very old version of M-PC (3.22.458.0) and if it was back then it would make life a lot easier for me now to rebuild a show in entirety in Onyx. I will just be taking screenshots.
No changes yet on exporting of values.
Paul,
Just curious why you have to re-create your whole show. You said M-PC. Just save your show file and all related ācue / screen settingsā. Then after making sure windows 10 64 bit is all up to date. Install the new version (4.4.1193 as of 5/5/2020) and just open your showfile. It will ask to be āoptimizedā and saved since itās coming from an older version. After that, you should be up and running. You may have to create some new āworkspacesā if you donāt like the defaults. But the shows cuelist and values should be there still. Unless Iām not understanding your question correctly.
Thanks for the response!
As Iām operating remotely from home I initially didnāt have the show file to test and had started the rebuild process manually on a local version of the software anyway.
I have got most of the way through it (all patching done, and more than halfway through the show build) so it is now inconsequential. Iām also building it ābetterā now anyway, after doing quite a bit of training on the software!
However, just for kicks - after getting hold of the original old show file I gave it a go and it just gets stuck at āLoading and optimizing show dataā. Iām sure I read somewhere many software versions updates ago that there was a point where old show files would no longer work; but maybe Iām mistaken, short of trawling through historic changelogs. Anyway; not an issue now, I like my new build better!
I still do feel like as a āhardā backup Iād love an export individual address cue values feature⦠Just to a CSV or the like. Any step up from screengrabs of the live output!
In a TV studio; where backups and redundancy are supreme.
Paul
Quick update - I got it!
Tried several times, and had to close out of the program manually each time.
Then, I noticed continue show was now available, even though it hadnāt ever loaded fully.
And that worked! Intesting. Cheers.
Just to add my formal +1 as a feature request for this.
Export cue values to CSV or XML or the like.
Cheers!
+1, for detailed cue info export, we have to give shows away so often, and not everyone could use onyx showfilesā¦
thx.
r.h.
