I’m trying to export a show from my companies NX4 that is being used at a different show and import that show file to a computer running a Martin M2PC (equivalent to a NX Wing). Every time I’ve tried importing the show from a USB Key ONYX says the show file is corrupt. Any idea’s on what I’m doing incorrectly or what I’m missing for this to work without problem?
When you say “export” what are you referring to?
Show files can easily be moved between consoles and PC setups that are running the same software version. Otherwise an older show file can be loaded onto a newer system. However, a newer show file can not be loaded onto an older system.
When moving showfiles. Simply save the show to a USB drive. On the new system Load the saved showfile.
