External button input
Is there an easy way to use an common external push-to-make button to trigger a cuelist?
The only workaround that I have in mind is using a simple DMX replay unit with button input to send a DMX-in signal that I map within Onyx or something similar with MIDI.
Before I go this “complicated” path, I wanted to check whether somebody knows a simpler way.
The application is simple: We have an exhibition booth where we have an interactive corner where visitors shall be able to trigger a certain lighting & video playback (sequence with higher priority) for this section, while everything else stay untouched. After this visitor triggered sequence released itself, this area shall be controlled by the “normal” Onyx show again .
Thanks for any idea
StreamDecks are very popular for this sort of application. Custom buttons can be created using a software package called Companion. These buttons can then be configured to output OSC network messages to ONYX to trigger playbacks.
Thanks for the great idea.
While the customer currently thinks of one of these massive “STOP” buttons out of manufacturing, the StreamDecks are an interesting option.
@Mathias -
Without knowing more about the system back bone, another option could be to use the NETRON EN12 (or similar model). These units have 10 contact closure options that can allow you to trigger cues (ONYX or built in) based on the contact triggered. Depending on how you structure your cues (thinking of a release macro at the end of the action) you could use a “gaint” E-Stop button that fires whatever cue and then can be reset.
This would need a little more designing/ researching to verify if it will work. But maybe @Edward could give his thoughts based on his knowledge of the product(s).
Anyway, just another idea that maybe outside the box thinking.
A nice idea. Using this approach, the E-Stop button would have to be manually “switched off” once the cuelist had completed, to allow ONYX to take back over control of the EN12.
Actually I’m considering buying an EN12 anyway.
Yet, from how I get the documentation, the push button inputs wouldn’t work in our use case:
If I don’t get the manual wrong, a cure records always all universes and a recall of such a cue overrides all outputs.
In our case, it’s a little bit more complicated: the push button shall trigger a respective cue list which will trigger the media server which vice versa feeds via NDI the Dylos for some luminaires, while the console needs to remain in control of all other fixtures.
Therefore, we need to get the information of “button pressed” into the console.
If the En12 would allow a “single universe” replay, we could indeed use the cue replay on one output, loop it into an DMX input and read it in the console. So, if I have missed that functionality, please let me know.
That is correct. On EN12, a cue includes all 12 DMX ports. Therefore, upon triggering a cue, all ports will output the cue data, rather than the incoming sACN or Art-Net.
Thanks for confirming.
I nevertheless just ordered the EN12 since I need a new Artnet node.
For the specific project, I think I will go for a basic DMX recorder with GPIOs that I feed into one of the EN12 ports that’s configured as DMX in.
Great to hear you have ordered an EN12. Please do let us know if there’s anything we can help with.
Thank you…
Now I need just to make myself familiar with the DMX-in configuration. While I should know myself as the feature was already there when I was with the Martin / Maxxyz / M-Series team, I have never used it before…
Please see the article below for information on configuring DMX In…
DMX Input
Let me know if there’s anything I can help with.
