Just trying to build up my default show using the new library rather than my user created fixture profiles.
The profiles I created crash Onyx when you try to patch them.
I have found a match for my fixture the ERA Lighting YY-L60C in the fixture search tool but cannot find it in the library in patch.
Am I missing something obvious ? using 1212, fixture appears to have been created in 2017.
Cheers
Andrew MacKay
Hello Andrew,
Onyx Fixture Finder is based on current (V.4.4) Onyx release build…
4.5 Beta uses an entirely new library database, provided by AtlaBase…
Please use the New Library Request form, to requires the required profile
https://support.obsidiancontrol.com/Content/Support/temp/New_Fixture_Library.htm
Regards,
Ofer Brum
Onyx Library Support
Hi all
I had the same issue using a user fixture create with 1212 version but I re-started software and I found it fine and work perfectly
Regards
EduardM.
