I have some colour chorus 48 in 32 channel id 901 to 908
I want to put a section in the middle to its own color I type in 902.7 thru 903.4 and hit enter what get selected is
902.4 to 902.7 and 903.4 to 903.7
What I want is every cell between 902.7 to 903.4 what am I doing wrong
This is on a M6 ver 4.0.1006
Are you able to select with the 2D plan view and get the desired results?
Have you confirmed your command line before pressing enter?
I know you have one more software release to go (4.0.1010) but I didn’t see any release notes indicating your problem, but that might be one of the “minor fixes”.
Thanks for your input but after playing around a little more I realized in the fixture select screen slice was selected not range
I did not think to look there when I was not in that screen and was just typing the numbers
all good now
Interesting, Like you, I wouldn’t have checked slice when using the command line like you were. Good to know that slice / range selection applies there also.
