I have a gig coming up where I’ll be using 12 Altman Spectra Cyc 100s (http://www.altmanlighting.com/product/spectra-cyc-100/)
I can’t find this exact fixture in MSD. Does anyone have any recommendations on an alternate 16bit RGBA fixture? Doesn’t need to be photometrically identical to an ss-cyc.
Thanks!
Already replied you on FB, Stan
Thanks! I’m gonna copy your response here so it’s in the forum if anyone else needs the solution.
“Simply use another RGBA (does not have to be 16bit) equivalent, than replace to the correct profile, in M-PC…
For example, Chauvet COLORado Batten, Chroma-Q Color Force, etc…”
You could also use the personality for the SpectraCyc 200. The fixture personalities are identical across the SS-50, SS-100 and SS-200. I haven’t used the SS-400 so i can’t verify that will match.
I would recommend that Smoothing is ON, and Master can be set to your preference. Personality 606 is where I run mine at.
Edit Sorry I just realized this was in MSD section. I don’t use that, so I don’t know if what I said will apply to that. But it’s valid for M-PC
