It may be a simple question but here we go.
I have a button with a white flash effect, where it turns on quickly and fades out quickly too.
If I’m using the colors from the live presets, the flash won’t work because the programmer has more priority than the buttons.
Is there any solution for this if I want to continue using the color presets?
Edit cue 1, select fixtures, click on color preset ,save cue 1.
If colors are part of Dylos, include Dylos zones to cue.
but this way I will be using the colors in a cue and that’s not what I said, I want to use the colors by clicking on the live presets.
Not possible
Create an intensity cuelist and color cuelists and trigger both by placing them next to each other (circle) on your touch screen and use two fingers. You can map the intensity cuelist to a hardware button. You can also add a macro to stop color cues.
I already imagined it wasn’t possible. It would be interesting to have some kind of priority setting in ONYX so that each technician can use it the way they prefer.
I use dylos to make flashes where you can select the color. create a 2d plan with all the affected fixtures, then create a dylos zone around them. then instead of selecting a video clip in dylos, you can just select a color for your source media. save that to a cue and you have your color. then create an override that just pushes that dylos zone to full intesity.
