Framing preset not recording
Software Version: 4.30.1274.0
NX Console Type or PC OS Version: Windows 10 Home
  1. Using fixture library July 28, 2026. I am not able to record framing information to framing presets or any other preset with the ELATION FUZE MAX PROFILE Ext Mode library profile. I’m able to record all other parameters (color, pan/tilt) to a preset but NOT framing. It will record to a cue. What am I missing or activated by accident?
  2. When I tried recording to a preset, the “F” does NOT show up, just 3 dots…
  3. It seems a “universal” issue as I’ve tried the Mac2K Performance library profile and it had the same issue.
@pmhchan -
I would suggest updating your fixture library and try again. I just did a quick test running software version 4.32.1311 and Library dated 19 July 2026 and had no issues. For the test I just patched 1 of the fuze max profile in extended mode, change a couple of the framing attributes, recorded to a preset. Then cleared the programmer. Selected my fixture and applied it. It went to the values I stored.
I also use a framing preset with some ETC / HighEnd Lonestars weekly with no issues. I also quickly checked the release notes and didn’t see anythign indicating that there was an issues with framing presets in version later than what you have. So also might be worth updating your software if possible.
Well, my library is dated July 28, 2026 so it’s newer than yours. I’m hesitant to move to a new software version right now as I’m at the end of rehearsals and getting for a show tomorrow. I currently have a workaround and will try updating the OS after the event. This hasn’t happened before.
I understand not going to a newer software version. But doing another library update would be okay. I’m also running library 20 Aug 2026 on my NX4 (4.32.1311) and have no issues. So I would agree that it is more of a software rather than library issue and since you have a work around would also wait until after your event(s).
