Software Version:
NX Console Type or PC OS Version: NX4 and M1
Hi there brains trust.
I am wondering if there is a way to make the “Function Assignments” for a playback fader load up as a default so that each time i load a cuelist into a blank fader all the buttons and faders are already assigned the “Go” - “Release” - “Select” i require?
When a Cuelist is created on a playback fader, by default the buttons and fader will be assigned the ONYX defaults, which are listed here… Function Assignments
There is not currently a way of customising these defaults. However, if you have a cuelist that is used on multiple playbacks, you can press the “Push To All” button in the Cuelist Options > Function Assignments screen, to set all cuelists of the same type to the same function assignments.
yeah, I have tried the Push to All option.
Only works with the same cuelist on other faders.
Unfortunately it doesn’t “Push” to other cuelists of the same type.
I work in TV and we load up the faders for each show as required.
Would be nice to not have to go through all those steps every time.
The ability to customise the default Function Assignments that are applied to newly recorded cuelists is logged on our system as a potential future enhancement (reference number ONYX-1129).
