Grand Master control in Onyx Manager?
Software Version: 4.30
NX Console Type or PC OS Version:Windows 11
I have converted over an old LJ install to Onyx, and the old LJM touch panel had buttons for Master Intensity (Full, 50%, and 10% up and down).
I do not see that functionality in Onyx manger .
Am I missing something obvious (I very well might)?
I don’t even see a way to control the Onyx GM via the command line / keypad.
Do I just need to grab all the fixtures , set the intensities to some set values, and create a series of Submaster CL?
TIA!
Hi @anthrum
Welcome to the forum.
The ONYX Grand Master cannot be controlled via the command line.
If you want to set fixtures to particular intensity levels, you could do this by recording submasters onto cue lists. Alternatively, if you want to be able to adjust the total intensity output like a Grand Master, you could record an inhibitive cue list. You can then use this cue list fader like a Grand Master, but just for the fixtures recorded in it.
Hi Edward,
Ok, thats fair, thank you for the guidance!
