Hello i have problème with grouping , when i select groupe and use hight light is work but when i use every 2 or one of grouping option my groupe is deselected ,
Hi @yns.asbane
Thank you for the video.
Please could you confirm what version of ONYX you are running?
Have you edited the Group Masks in your show file, or are they still the ONYX defaults?
Hello yes i edit the groupe by swap fixture then clone same fixture including groups , i load old show its work fine then i do the same cloning wihtout group and its work
Please email us a copy of your show file to support@obsidiancontrol.com, and we will then be able to investigate further.
