Highlight doesn't bring up the intensity of fixtures
Hello everyone, I’m new here.
I just got the NX1 Console and am currently going through the most recent recorded webinars, attempting to absorb as much information as possible. I was able to get my NX1 to output DMX on the Capture Demo file from the webinar; now I am attempting to locate the fixtures using the “HighLight” option, but it only marks the fixtures within the Capture and does not increase the fixture intensity to make my pan/tilt configuration easier; is there a way to change this in settings because I couldn’t find any information on it on my own?
Puedes quedarte pulsando highlight unos segundos y te aparecerá un menú para ajustar los valores de highlight, tanto el que tienes activo con next/prev, como los que quedan en segundo plano…
Aunque por defecto deberías ver cómo se enciende el que seleccionas si tienes el patch bien hecho…
Si estás probando con un fichero de demo y capture lo tienes bien comunicado con onyx el patch se lo puedes pedir a capture y suele funcionar bien…
Espero haberte podido orientar un poco…
Thank you very much for your input. Looks like it was just some kind of a bug either on the Onyx or Capture side, today when I turned on the console again and software issue just fixed itself even tho I tried to reboot both Capture and NX1 yesterday, weird but it works now so I won’t complain.
