Hi Guys,
I learn Dylos at the moment and stumbled across some work flow barriers.
How can one blend two Dylos zones together? (same parameter)
I tried masking with no success.
Coming from VJ software (Resolume & Vdmx) this is a typical workflow to merge two layers. (Alpha blend e.g.)
During the Webinar @Matthias mentioned this isn’t possible (yet?), but not explicitly.
I attached a short clip, showing two generators crossing each other - but only one is visible on stage.
no.
if you want to see two generator gradients at the same time in one area, you need two zones one above the other, the lower zone in the composer layer view, have to set to opacity zero, you can also see this kind of keying in preview.
