Hi @Edward
as this was more linked to this topic I will answer in this one (reference BPM/Tap Sync on FX - ONYX / Suggestions - Obsidian Control Systems)
I tried to build this effect using the non P/T bound effects on the Tilt. I could use the modes 9 - 12 for that. The problem there is, that I always have to use a step of min 3 to make that run. So when I want to have this effect only on 2 groups I cannot use these modes. When I use 7/8 I could build that, but as this effect is pretty fast the problem with these modes is that the movement starts in one direction (like up), then intensity would go to 100%, then tilt would go down and afterwards intensity would turn off again. I would like to avoid this first up movement.
What did you mean with “and then set the parameter value to the midpoint rather than the low point?”
Thanks
Philipp
