Trying to get Shehds fixture Led beam 8x12 RGBW 38 channel fixture on the older platform. was able to build the 9 channels but 38 wont load correctly. tryed to import from laptop but that won’t work either. Any help would be appreciated.
You can request a profile for the older version for a small fee through @Ofer_Brum. Ofer is great and will get you taken care of. Here is a link to his request form.
That said, is there a reason you are still using such an old version? I would encourage you to consider updating to the current version as there are a lot of new features. However before you do, you do need to make sure everything in your system will still function as there has been the library change in addition to the reduction of free universes back to 1 and some limited playback restrictions if there is no official control surface attached.
