is there an option to have a “grouped virtual fixture” for something like a PixelBar. So that you can use every Pixel on its own, but you could also use the virtual fixture which would affect all RGB LEDs at one. I know that you could group every single LED but when creating a wave effect inclusing a single fixture and a group does not work. In this every Single LED of the Pixel Bar is triggered and not all at once.
I think you got my question wrong. I have an LED Bar that has 48Ch and yes I used the 48Ch mode with the virtual dimmer enabld in Onyx for that one.
I would like to combine that LED bar together with “Single RGB Fixtures” (like an normal PAR light) within a group, BUT If you create an dimmer effect via the FX on the dimmer it will again “wave” that for every single LED in the Pixel Bar.
Select your Led Bar Basic + led par fixture to set the dimmer to 100% + no fx.
Deselect all fixtures.
Select all bar part fixtures (not the main led bar one) and rgb spots - > apply color fx waves not dimmer waves.
This is it.
Alternatively, do it in Dylos
