hello,
we have searched for days, for a solution to start a new cuelist which is following a timecode, coming from nx wing ltc input, by another timecode cuelist which has a macro on last timed cue which is triggering the next timecode cuelist with a offset of time values.
is there a solution??
so can a timecode cuelist be triggered from another timecode cuelist automaticly, so that we do not have to press go manually at every songstart???
we are very depressed about this, we see no way to do that in onyx!!!
thx.
r.h.
Share a screenshot how you are triggering the next cuelist with a macro
hello, not before monday.
but in short, we trigger a first cue in a second cuelist by a at the end of the first list with the last timecode value in the list. all cues expect the first one in every list has a timecode value,
we also do macros for change bank, select cuelist nummber two and for releasing the current list.
the bank changes, the cuelist gets selected the double arrow is shown in front of the first cue,
but the timecode is catched not before we press manually a go for this list.
thx.
r.h.
Using CUE XX as the macro will cause the list to pause. this is intentional.
leave the cue number field empty to activate the list and have it listen to timecode.
wow, thank you. can not wait till test it.
thx.
r.h.
…really, it works without fancy workaround…
thx.
r.h.
