I saw the new update can import .dwg files. Where does that functionality occur? I can’t seem to find it.
It’s under the File/Import menu
The import of .DWG and .DXF files is a plugin for the Visualizer module.
It is only available for Pro versions, and can be accessed via the ‘File’ - ‘Import’ menu option.
Where can I find that plugin.
I am trying to import some dwg files, and don’t see an option with the latest version MSD_Pro_6_0_160804 to import dwg. I looked in Modeler, and did not see it.
Alright, found it…Open Visualizer.
File - Import
Save As (to the directory, where you want to save the items)
What did I miss?
