Incompatibility ELC NodeGB8x and RDM10
Hi i discovered ther is an incompatibility between ELC NodeGB8x and RDM10.
In my Setup the ELCs act as sACN Node the RDM10s are configures as Splitter.
If i Use the latest ore older ELC dmxLan software, only the UIDs are found during Discovery, but its impossible to fetch any Data from the Devices connected down the line pluged int the RDM10s Output-Ports.
Even if i try to use the RDM-Controler-Function direct build into the ELC-Nodes, there also only the UIDs can be discovered, but no Data is Fetched from the Devices.
Hi @Q-Light
I have sent you a DM to allow us to troubleshoot more easily.
