So I’m trying to do an intensity chase where each scene has different fixtures at 100% intensity. When Cue 2 triggers, the fixtures that were previously at 100% in cue 1 stay at 100% for cue 2 also. I know I can record a lower intensity value to all fixtures except the ones at 100% for each cue, but I’m hoping there is a way that I can make them drop back to the intensity of the current cue on my main Cue list? That way I can use the same chase at different points with different starting intensities.
I’m pretty sure this has to do with the “Tracking” option in the cue settings. You can read more about that here: https://support.obsidiancontrol.com/Content/Cues_and_Cuelists/Cuelist_Types/Cuelist_Options.htm
Try disabling this and run the chase again
