Hi!
I am new and would like to know if it is possible to record a path on the pan-tilt field of a moving head and then play it back.
And is it possible to record my own path for the fade (in the ‘Selected Cuelist Window’)?
Thanks for the effort!
Hi!
Are you trying to build a ballyhoo or track someone/ something?
Ballyhoo is fairly easy to build. Reference this.
If you are trying to track someone. You could build a cue list with multiple cues that has each position you are trying to hit. Or you could also make an override fader with Q blender to follow whatever with your fader movement. Reference this.
Hope this points you in the right direction.
Many, many thanks. I was looking exactly for the possibility of Q-Blender. ![]()
