Hello I have a question about the fx. Is there a way to program 3 ledbars to fil from the center? Without programming each individual led.
I am using 3 GLP Impression X4 Bar 10 pixel. 48ch
You can use Dylos to run a effect from center to outside. Color or intensity.
Thank you very much for the info am using software version 4.2, because I am still using an enttec dongle. So is there a way to accomplish the danger effect without Dylos.
HM… maybe try by selection from inside - out?
