Lights can't keep up with onyx?
So I’m having an issue where I set up a simple chase that switches through colors. It works great at lower speeds, but when I crank the speed up to 150+ BPM it seems my lights are just skipping certain DMX commands? They seem like they can’t keep up? Is this normal? Is there a fix or work around?
which hardware setup do you use? we notice similar behaivior of onyx on some nx1. mostly under heavy universe and parameter load.
Hi @ilovestuffforreal
Welcome to the forum.
Please could you confirm which version of ONYX you are running?
How are you sending DMX to your lights? If your lights are directly connected to your ONYX controller, please confirm which ONYX console you are using. If you are connected via an Ethernet to DMX gateway, please confirm what device you are using, and which protocol you are sending.
What fixtures are you using?
