Limiting Intensity Of Fixtures
Software Version: 4.32.1302
NX Console Type or PC OS Version: NX Wing
Question regarding limiting the intensity levels of certain fixtures.
Is there a way to set the limit within the fixture profile(Example: Max Intensity Output is 50%) or is the best course of action to create an inhibitive cuelist for the desired fixture and setting it to the level I am needing? Inhibitive is simple enough but wondering if there are other ways.
Thanks!
Hi @frankschabell
The best option is to record the fixtures into an inhibitive cuelist.
There is no dedicated “Max Level” or “Topset” option.
That is perfect and what I thought was the case. I actually don’t mind having the Inhibitive Cuelist on different bank where I can adjust it if needed :slight_smile: Just wanting to ensure I guide my client properly.
Thanks for the fast reply,
Cheers!
-Frank
Strange idea, but
Offset intensity @ -50
With this method, it would mean if you typed 1 @ 25 ENTER, the fixture would still be off, as theoretically it would then be at -25%.
Whereas if you use an Override cuelist, everything is scaled.
