hello,
how can i lock the menu for dj´s and other users?
the dj´s used the software for ready playbackts but he don´t program the show and other things.
or how can I disable the record function?
Hello, there is no such function inside Onyx
Thomas,
While @Sylvain_Guiblain is correct that there is no record lockout function in ONYX, I would suggest you consider looking into ONYX Manger.
Several installs use this to only display a customized “touch” panel layout for simplified operation. Things like DJs, bar managers, etc. It can be set to start on computer startup or launch of ONYX. Then there is a “exit” option to take you back to the actual programming of cues.
