So I installed a Martin RUSH PAR2 RGBW recently, which would also be my first light to have a zoom lens.
I have the light configured to an override slider. I have have set the particular color wanted (100%, 100%, 60%, 60%), intensity to 100%, and zoom to 20% (works out to be about 30 degrees).
Now, I want to be able to dim the light without the zoom moving. Currently, the slider brings down light, but also affects the zoom. I tried unloading the channel and re-saving it, etc, but that doesn’t seem to be it.
Why is this set as an override and not just a regular cuelist? If it was saved as a regular cuelist, then when you activate the cue you will have the look you want and the slider should only affect the intensity.
Now set it up as a cuelist is probably what I am missing. I set up a few cuelists in the past, but had not revisited them (or even thought of them) in a long time.
I’ll work with that and see if I get what I am aiming for.
