I am using M-Play touch faders with a brand new laptop (i7-13gen intel) an during the show, when I faded the intensity of the led lights, let’s say from 100% to 50% in 8 seconds, I can see the light flicker, like not fading smoothly. I am wondering if there could be a lag in data transmission that makes the fade not going smoothly when connected to m-play via laptop? Thanks!
Você pode conferir o progresso do fader na própria tela do onyx, se ao mexer o fader ele faz o comando corretamente na tela logo não tem problema algum com a M-play
Gracias! It’s pretty hard to see the progression of a fade but when I look at the data %, I don’t see any obvious issue or lag…
