Hello.
I have two quick question regarding the M2GO
I have not had the issue before, I’ve attached on of the M DMX boxes to the console, under the diagnostic menu in USB view I can see the Martin M-DMX it however does not show under the DMX settings USB2DMX tab. This shows “No USB2DMX device available? Any suggestions the box works via M-PC running the same software version on a laptop.
I have purchased a NX Sync to use on a console running release 3.70.885.0.
Is there anywhere in the console menus that show this device is working? I would hope it’s backwards compatible with the M2GO?
Am I using the LTC option for using this device? for input?
I plan to send SMPTE via Timelord to the NX Sync.
Thanks in Advance
Timber
