Looks like I need to replace the CMOS battery on my M2GO, not keeping the date on reboot and occasionally hanging on powerup.
Does anyone have any experience of replacing the CMOS battery on an M2GO? Hoping it’s an easy job
Did you get your CMOS batt replace?
It is fairly simple.
Thanks very much for the reply. I haven’t yet wasn’t sure if it would be soldered in or replaceable. Can you tell more?
Ours had a little connector on the end. And the replacement we found had the same one on it also. So we just unplugged the old and plugged in the new. Took longer to get the console opened.
Search on xump.com for a CR2032 with 3.5” wire leads and a Molex 51021-0200B
That’s great, thanks very much for the info and link and it certainly does help
Will get one of those ordered.
