I searched the manual regarding this, but found no info… is it true that macros (even though they can be added), doesn’t work in Override cuelist?
Or else, what am I doing wrong?
Hi Anton,
I can’t say I have ever tried but I don’t believe you can use a macros in a Override cuelist.
What are you trying to achieve?
Cheers
Steve
So I’ve got main intensity faders set up as inhibitives (which is great for controlling running intensity effects). However, this also means that I can’t force up the intensity of fixtures that doesn’t have a “light on cuelist” running… the idea was to have an override sending triggers to the inhibitive fader (so i both can control intensity and max effect speed on one fader).
Overrides have no cuelist macros.
