Hi everyone. After nearly 2 years of waiting for my M1 to be repaired with no clear solution in place. I was wondering if anyone else has managed to use their M1 as a control surface like the M2GO with MPC? I’m interested to find out if anyone has explored this path.
Cheers!
What issues does your M1 have?
Hi Matthias,
Originally a White screen issue. It’s been through 4 different repairers over the past 21 months as Martin handed over to Elation and then changed distributors in Australia. It’s had 3-4 motherboard replacements in attempted repairs and I’ve just been quoted for another board replacement but am growing sceptical about this being the primary issue. I know aftermarket boards were tried on 2 occasions.
If I can mod the control surfaces to recogniseable USB peripherals I’ll do away with the M1 's internal PC and create something that works
I love the console but this saga has worn me down…
Cheers!
Hi everyone,
I’ve had success running the surface of my M1 on MPC but no luck on getting DMX out via the M1 DMX Card
The One-Key USB mounts when plugged into the DMX Card
Artnet out is working fine.
I’ve plugged the One-Key usb into the mpc.
Nothing is plugged into the dmx ports but the ports are not available to assign.
I’m running 3.70.885.0
Any help or thoughts would be appreciated.
Here is the log after starting the Codemeter Service:
2020-02-27 16:12:51: API Error 200 (ENTRY NOT FOUND) occurred!
2020-02-27 16:12:52: Access from local(IPV6) to IFI (Handle 611)
2020-02-27 16:12:52: Handle 611 released
2020-02-27 16:12:54: Access from local(IPV6) to IFI (Handle 612)
2020-02-27 16:12:54: Handle 612 released
2020-02-27 16:12:57: Access from local(IPV6) to IFI (Handle 613)
2020-02-27 16:12:57: Handle 613 released
2020-02-27 16:12:57: Entry (100637:297726121) not found - Event WB0200 (ENTRY NOT FOUND), Request IP-Address local(IPV6)(WORKGROUP\SYSTEM,LinkManager_Module.dll) with UserLimit
2020-02-27 16:12:57: API Error 200 (ENTRY NOT FOUND) occurred!
2020-02-27 16:12:58: Entry (100637:39808015) not found - Event WB0200 (ENTRY NOT FOUND), Request IP-Address local(IPV6)(WORKGROUP\SYSTEM,LinkManager_LJ.dll) with UserLimit
2020-02-27 16:12:58: API Error 200 (ENTRY NOT FOUND) occurred!
2020-02-27 16:12:58: Entry (100637:39808030) not found - Event WB0200 (ENTRY NOT FOUND), Request IP-Address local(IPV6)(WORKGROUP\SYSTEM,LinkManager_M2PC.dll) with UserLimit
2020-02-27 16:12:58: Entry (100637:5077553) not found - Event WB0200 (ENTRY NOT FOUND), Request IP-Address local(IPV6)(WORKGROUP\SYSTEM,LinkManager_M2GO+.dll) with UserLimit
2020-02-27 16:12:58: Entry (100637:39808029) not found - Event WB0200 (ENTRY NOT FOUND), Request IP-Address local(IPV6)(WORKGROUP\SYSTEM,LinkManager_M2GO.dll) with UserLimit
2020-02-27 16:12:58: Entry (100637:2048) not found - Event WB0200 (ENTRY NOT FOUND), Request IP-Address local(IPV6)(WORKGROUP\SYSTEM,LinkManager_4UniversePack.dll) with UserLimit
2020-02-27 16:12:58: Entry (100637:39808033) not found - Event WB0200 (ENTRY NOT FOUND), Request IP-Address local(IPV6)(WORKGROUP\SYSTEM,LinkManager_M6.dll) with UserLimit
2020-02-27 16:12:58: Executing Broadcast for CodeMeter License Servers
2020-02-27 16:12:58: Network server IP inquiry from client 10.7.2.8
2020-02-27 16:12:58: Entry (100637:2176) not found - Event WB0200 (ENTRY NOT FOUND), Request IP-Address local(IPV6)(WORKGROUP\SYSTEM,LinkManager_Ether2DMX8.dll) with UserLimit
2020-02-27 16:12:58: Network server found with IP 10.7.0.21
2020-02-27 16:12:58: Network server IP inquiry from client 127.0.0.1
2020-02-27 16:12:58: Network server found with IP 10.7.2.8
2020-02-27 16:12:58: Network server found with IP 127.0.0.1
2020-02-27 16:13:00: Entry (100637:297726121) not found - Event WB0200 (ENTRY NOT FOUND), Request IP-Address local(IPV6)(WORKGROUP\SYSTEM,LinkManager_Module.dll) with UserLimit
2020-02-27 16:13:00: API Error 200 (ENTRY NOT FOUND) occurred!
2020-02-27 16:13:00: Entry (100637:39808015) not found - Event WB0200 (ENTRY NOT FOUND), Request IP-Address local(IPV6)(WORKGROUP\SYSTEM,LinkManager_LJ.dll) with UserLimit
2020-02-27 16:13:00: Entry (100637:39808030) not found - Event WB0200 (ENTRY NOT FOUND), Request IP-Address local(IPV6)(WORKGROUP\SYSTEM,LinkManager_M2PC.dll) with UserLimit
2020-02-27 16:13:00: Entry (100637:5077553) not found - Event WB0200 (ENTRY NOT FOUND), Request IP-Address local(IPV6)(WORKGROUP\SYSTEM,LinkManager_M2GO+.dll) with UserLimit
2020-02-27 16:13:01: Entry (100637:39808029) not found - Event WB0200 (ENTRY NOT FOUND), Request IP-Address local(IPV6)(WORKGROUP\SYSTEM,LinkManager_M2GO.dll) with UserLimit
2020-02-27 16:13:01: API Error 200 (ENTRY NOT FOUND) occurred!
2020-02-27 16:13:01: Entry (100637:2048) not found - Event WB0200 (ENTRY NOT FOUND), Request IP-Address local(IPV6)(WORKGROUP\SYSTEM,LinkManager_4UniversePack.dll) with UserLimit
2020-02-27 16:13:01: Entry (100637:39808033) not found - Event WB0200 (ENTRY NOT FOUND), Request IP-Address local(IPV6)(WORKGROUP\SYSTEM,LinkManager_M6.dll) with UserLimit
2020-02-27 16:13:01: Entry (100637:2176) not found - Event WB0200 (ENTRY NOT FOUND), Request IP-Address local(IPV6)(WORKGROUP\SYSTEM,LinkManager_Ether2DMX8.dll) with UserLimit
