Master Faders for Multiple Parameters
Software Version: 4.30.1274
NX Console Type or PC OS Version: PC Version
I have a lighting fixture that has three rings of LEDS. Each ring has an individual channel for Red, Green, Blue, and White. There is a channel for each of these ring and colors (ex. Red1, Red2, Red3) and as such has a parameter fader for each. What it doesn’t have and what I’d like to learn how to do, is a master fader that would control the color intensity for all three rings at once. Any help?
@jaybrinson23 - welcome to the forums.
Knowing the fixture in use would be helpful. We can then check to see what modes are available. Without knowing these specifics, it’s hard to say. But in general, hopefully there is a virtual dimmer option for each of the RGBW rings (parts) and then a master dimmer for the entire fixture. Once more information is provided we can check and then advise accordingly.
Thank you. I believe we are running the following:
  • SHEHDS Moving Head Light LED 19x15W RGBW 4in1 Beam/Wash/Zoom Effect Stage Lights Professional DMX512.
    I’m also attaching the channel layout currently in onyx based on the manufacturer’s booklet.
    There are also three channels not shown in the picture:
  • Ch 22 Tilt Fine
  • Ch 23 Restoration
  • Ch 24 CTO
Correction, we are not running the shehds brand lights, they are some other brand.
As @Watson mentions, if you could confirm which fixture you have, and what mode is currently patched in ONYX, we will be able to advise the best way to achieve what you are after.
To confirm, have you patched a “SHEHDS Moving Head Light LED 19x15W RGBW 4in1 Beam/Wash/Zoom” in ONYX, in order to control a different model of fixture from another brand?
não é só usar o dimmer virtual?
