Hi!
Anyone know how can I define a maximum pan/tilt limit that moving heads won’t go beyond?
Thanks
Hi!
Thanks
The “Offset” option can be used to prevent a fixture’s Pan/Tilt parameters from going above a certain value, or below a certain value…
Offsets
However, it is not possible to set Pan/Tilt limits to prevents beams from leaving a particular area.
Ok,
Thanks Edward
If you absolutely need to restrict it maybe you could try to recreate your fixture by copying it in the library editor and restrict the dmx values for that fixtures…
It’s a good solution, but unfortunately it’s too slow and too binding for everyday use.
It often happens in theaters or live performances that you have to apply effects that must not exceed certain limits. Changing the parameters in this way then does not allow you to go beyond that limit (should there be an occasional need for that event).
@Edward Could you add this feature on software request please? Thank you very much
Logged as ONYX-601 ![]()
this feature is very important, because we have to use more often hybride fixtures with build in lasers. and if we get that, we can do faster and better security adjustments, and be able to program this into cues would be great!
